Activity Forums Zaxwerks Mac Book Pro & Invigorator
  • Mac Book Pro & Invigorator
    Posted by Eric Martin on August 20, 2006 at 7:33 pm
    Having some issues getting 3D Invig (3.0.1) to work right on my new Mac Book Pro. Not only does it
    crash A LOT, but apparently, the old version of Illustrator (8 – which is the only version I’ve used that
    produces “usable vector files”) will not run/install on the new system. Meanwhile, Ill CS files don’t look
    like they’re recognized at all, as they produce “no usable vector files”. Is there a work-around besides
    buying Invig 4 (don’t have the $400 bucks to spare), and does 4 actually remedy any of these
    issues?
    Eric Martin replied 20 years ago 2 Members · 2 Replies
  • Jon Okerstrom
    August 21, 2006 at 4:01 am
    Hi Side FX,
    First of all, go ahead and install Illustrator CS or CS2. Since you’re using an older version of Invigorator, you’ll need to use the export command and choose a legacy Illustrator format. You won’t find the option under Save As… The newer Illustrator verions will work fine.
    You didn’t say which version of AE you’re using, but that choice, in combination with the relatively old version of Invigorator may have something to do with the crashing.
    For what it’s worth, you could upgrade to Classic 4.0 from 3.0 for less than $100 dollars. That would likely solve your crashing problem — though you’ll still be running under rosetta until AE and the plugins are offered in universal format.
    Does this help?
    Jon
  • Eric Martin
    August 21, 2006 at 5:55 pm
    Very much, thanks. BTW, AE 6.5 – and the 3D plug-in is on my employer’s machine, so if I want it for myself I wouldn’t have the upgrade option. I’ll shop around.
