Activity Forums Adobe After Effects Mac AVI import/render
  • Mac AVI import/render
    Posted by Andy Tubbesing on January 30, 2006 at 4:20 pm
    I’m using AfterEffects 6.0 on a Mac to add effects to digital video footage (mini DV).
    The files were supplied from the client in AVI format, which I open in Quicktime.
    Questions:
    1. Since AE 6 on the Mac does not support AVI import, do I export the AVI files out of Quicktime as uncompressed QT movies before importing them in AE?
    2. Do I export them to QT movies at 29.97 or 59.94?
    3. When I do import the movies into AE, do I separate the fields (Interpret Footage>Separate Fields>Lower Field First) and checking the Motion Detect checkbox?
    4. When I’m done adding the effects, do I export from AE to uncompressed QT movies with Field Render set to Off, then export from Quicktime to uncompressed AVI files to give back to the client?
    5. In tests I made, even though I added no compression or color-correction throughout the process, the final exported AVI files were noticeably sharper and warmer (less green) than the original AVI files the client supplied. The final AVI files actually looked better, but will cause problems when the editor tries to match shots. Any way to keep this from happening?
    Andy Tubbesing
    Roland R. kahlenberg replied 20 years, 7 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    January 30, 2006 at 4:33 pm
    Checkout https://www.popwire.com/ for their WMV import/export features. I believe there is a free version that allows for import only functions.
    HTH
    RoRK
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
