Activity › Forums › Apple Final Cut Pro Legacy › .m2v files crashe finder
Posted by Skychase on June 23, 2005 at 5:06 amOS 10.3.8, upgraded to FCP 5. Finder crashes whenever I simply click on a .m2v file, even files created before the FCP5 upgrade. Tried reinstall of Quicktime 6.5.2, but problem persists.
David@motivitypictures.com replied 20 years, 8 months ago 5 Members · 7 Replies -
Tom Wolsky
June 23, 2005 at 8:01 amIt can sometimes take a very long time for the finder to load a .m2v file in column view. If you short that’s not it, then it’s possible the file is corrupted.
Skychase
June 23, 2005 at 11:56 amWhen I import *any* file into DVD SP, it crashes the app, including .m2v’s that worked fine before.
Miha_pece
June 23, 2005 at 1:05 pmI guess you repaired permissions after upgrade?
Miha Pece
Audiovisual Laboratory
ISN-ZRC-SAZU
Slovenia -
Skychase
June 23, 2005 at 4:26 pmyes, I repaired permissions. Whenever I try to open a folder containing any .m2v file in DVDSP 4, it crashes the finder, but not the app.
Peter Mcauley
June 23, 2005 at 4:38 pmThis may be unrelated but FCP 5 will not run on 10.3.8. 10.3.9 is the mnimum
Peter McAuley
Axyz Edit
Toronto
G5 dual 2.0
4 gigs ram
10.3.8
FCP 4.5 HD
QT 6.5.2
Kona 2 v1.1 with K Box
4 X 250 gig external F800 Lacie firewire drive
2 X 23″ Apple cinema display -
January 28, 2006 at 12:04 amDid you ever find a solution to this problem…wow I can’t believe I found someone else with the same issue. The only work around is to select the .aiff file first and then highlight the .m2v file second…that way the finder won’t close and you can import into DVDSP and it will work fine…however I still don’t know how to fix the problem…
And it is a problem…
Any advice?
The only thing I can conclude so far is that when we upgraded FCP or even apple updates there is something about how they work with the newer operating system. I can see the exact same .m2v file on my Powerbook and it’s fine. And that is 10.4.4 unlike my G5 which is still 10.3.9
David
