Activity Forums Adobe After Effects m2t files opening
  • m2t files opening
    Posted by Mailo Homolas on October 30, 2009 at 2:56 pm
    Hi i tried open m2t file (HDV movie camera record) into AE cs4(not trial) and AE writes “AE: AEGP plugin AAF: Error occured while creating project (5027::12)
    Pls where is the problem?
    Kevin Camp replied 16 years, 11 months ago 3 Members · 3 Replies
  • Kevin Camp
    October 30, 2009 at 6:41 pm
    try cleaning/purging the media cache from the cache preferences in ae.
    if that doesn’t help, you might just convert the media using mpeg streamclip (free & multiplatform, just search for it) or another utility or export from an nle as a different format & codec. media like hdv doesn’t play nice with after effects anyway, so if you convert it you may be better off. try converting to quicktime lossless mov, quicktime photo-jpeg, apple’s prores (need fcp) or avid’s dnxhd (free from avid, uses quicktime format).
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Marcello Mazzilli
    October 30, 2009 at 7:21 pm
    Instead of converting, try just re-wrapping. Is faster and you’ll lose no quality. Try CLIPWRAP software.. It will rerap m2t footage to mov footage (keeping m2t format inside). It might be easier for AfterFX to work with it.
    siRoma di Marcello Mazzilli
    Corporate video productions in Italy
    http://www.siroma.com
  • Kevin Camp
    October 30, 2009 at 8:10 pm
    rewrapping is usually preferable, and it may correct that error, but if the footage is still encoded by a codec that uses inter-frame compression (or temporal compression, b-frame/p-frame compression), like hdv, mpeg-2, h.264, etc., ae will still not work as well with it and it can lead to general flakey behavior in ae.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
