Activity Forums Media 100 M100sw Should importing FCP clips take forever ?
  • M100sw Should importing FCP clips take forever ?
    Posted by Joe Garvin on December 10, 2005 at 3:43 pm
    Two problems
    first I can not get my Trial version of m100sw to load on my laptop I at first I did not get the access code from boris ( but a nice e-mail solved that aspect ) Now I can not get the program to load on my computer. I keep getting an application failed to launched due to a “shared media library problem” message
    G4 laptop w/1gb of ram with os 10.3.5
    I wanted to try the new version since I never had time to play with the beta version.
    but I still had the beta version in a folder and found it was able to load and open with the beta version of m100sw
    second problem
    I used FCP to capture video files to a fire wire drive .
    When I opened m100sw and tried to import a 40 minute clip my G4 told me that it would take almost 5 hours to render video the video files
    I this the correct amount of time I thought that the video file should be drop and drag or import by reference from the original clip on the firewire drive.
    I hope this is not how sw works…. if so without capture ability this program is useless
    Is there a way to create digitized files which do not take as long to import . I was hopeing to free up my real M100 so that I could work on two projects at once
    Thanks Joe
    Floh Peters replied 20 years, 5 months ago 2 Members · 1 Reply
  • Floh Peters
    December 10, 2005 at 6:34 pm
    [joe garvin] ” I keep getting an application failed to launched due to a “shared media library problem” message”
    I
