Activity Forums DaVinci Resolve Lut to convert XYZ to RGB with DCI-primaries
  • Lut to convert XYZ to RGB with DCI-primaries
    Posted by Knut Jansohn on January 24, 2012 at 10:00 pm
    I would like to preview XYZ on a Monitor, which is calibrated to DCI color-gamut (Red: 0.680x, 0.320y, Green: 0.265 x, 0.690 y, Blue: 0.150 x, 0.060 y), white: 0.314 x, 0.351y and gamma 2.6.
    So I think I need a 3d-lut to convert.
    I have seen that ‘Light Illusion’ offers luts for 100 GBP.
    Any idea where to get it more favorable?
    Thanks & Regards
    Knut
    Knut Jansohn replied 14 years, 7 months ago 4 Members · 9 Replies
  • 9 Replies
  • Ola Haldor voll
    January 25, 2012 at 8:40 am
    I’m not sure you could beat a deal like that. £ 100 for a LUT that you potentially can earn back in no time doing grading is not a steep price if you ask me.
    The alternative is to buy the software and make it yourself.
  • Knut Jansohn
    January 25, 2012 at 12:02 pm
    Well, would be grart to heare, how to earn 100 GBP (=120 €)in no time 🙂
    I assumed that this is a very common lut, so that it would be a 5 min copy&paste job for them.
    And I’am far far away from earning 120€ in 5 min 🙂
    Anyway if there is no better deal I will order…
  • Knut Jansohn
    January 25, 2012 at 10:22 pm
    Hmm, no further reply.
    So all you fsi- and dreamcolor-user have purchased at ‘Light Illusion’?
    Or are you not interrested in checking the XYZ-results – maybe I miss something??
  • Gabriele Turchi
    January 26, 2012 at 3:00 pm
    i don’t see why you want to check the XYZ on a “non XYZ” display …
    g
    Davinci Resolve Control Surface
    MacPro
    Cubix desktop 4
    2 Red Rockets
    GTX470+GTX470+GTX285
    24GB RAM
    HP Dreamcolor
    Panasonic 58PF Plasma
  • Knut Jansohn
    January 26, 2012 at 4:16 pm
    [Gabriele Turchi] “i don’t see why you want to check the XYZ on a “non XYZ” display …”
    For XYZ are virtual primaries, there is no XYZ-display existing.
    So if you want to view XYZ-coded colors you have to convert to real primaries.
    Depending on the ‘wideness’ of the real colorspace you will see a part of the XYZ-coded colors.
    After grading in 709 I have converted a short to XYZ for DCI.
    But as there is a gamma 2.6 and other whitepoint and lower lightness. I would like to get an idea how it will look in dci.
    This should be possible with a monitor that meets dci-specification.
    Regards
  • Gabriele Turchi
    January 27, 2012 at 5:08 am
    so you are saying that you have graded for 709 ,
    than converted to XYZ (with a lut i guess ) , now you want to watch that on the same display (but setting the display to P3 color space) and you need a XYZ to 709 Lut ..
    so what is the point of converting 709 to XYZ if you have than to convert it again to watch it ?
    i actually thought that DCP compliant projector could accept XYZ directly …
    g
    MacPro
    Cubix desktop 4
    2 Red Rockets
    24GB RAM
    HP Dreamcolor
  • Jose Lomeña
    January 27, 2012 at 7:37 am
    Why not easydcp player?
  • Knut Jansohn
    January 27, 2012 at 11:46 am
    [Jose Lomeña] “Why not easydcp player?”
    Thanks a lot. I will have a look at it.
  • Knut Jansohn
    January 27, 2012 at 12:14 pm
    [Gabriele Turchi] “converted to XYZ (with a lut i guess )”
    Yes.
    Graded on a Broadcastmonitor, after finishing the client asked me to build a version for DCI.
    To check the results of the conversion-lut I would like to preview it on an other monitor in p3.
    Due to the different whitepoint and an lower brightness I suppose that there is perhaps more required than a mathematical conversion.
    [Gabriele Turchi] “thought that DCP compliant projector could accept XYZ directly”
    But then it first convert internally to its own real primaries
