Activity › Forums › DaVinci Resolve › LUT relinking
  • LUT relinking
    Posted by Nat Jencks on February 21, 2014 at 11:32 pm
    I have a resolve project that was started on v9, and has been imported into v10 on a different boot drive, but one of the LUTs in the node tree is not relinking, despite the fact that it should be in the identical path.
    I can choose the LUT by hand, but would have to do this for thousands of shots.
    Is there a way to check the exact file path that resolve is expecting for this LUT, or any way to troubleshoot this?
    Any advice appreciated.
    best-
    -Nat
    Juan Salvo replied 12 years, 7 months ago 2 Members · 3 Replies
  • Juan Salvo
    February 22, 2014 at 5:16 am
    Copy the LUT into the appropriate folder, AND the supporting “.LUT” folder from the previously working version. 😉
    https://JuanSalvo.com
    https://theColourSpace.com
  • Nat Jencks
    February 23, 2014 at 4:21 am
    Indeed, Indeed 🙂
    The question remains though, why does this hidden .LUT folder exist, and when does resolve place LUTs in there? The LUT in question was one that I installed by hand and certainly never moved to the .LUT folder… how do LUTs get moved in there and why? Perhaps this is where the system places LUTs when projects have been saved with the LUT check box checked, and then get imported to a new system?
    HMm..
    best-
    -Nat
  • Juan Salvo
    February 23, 2014 at 4:50 am
    Nah, I think there’s an integrity check on the LUTs and this is where resolve moves qualified files after said check on startup, or when you hit the update LUTs button.
