Activity Forums Apple Final Cut Pro Legacy lumix gx8 24P UHD importing as 23.98
  • Shane Ross
    January 12, 2016 at 11:53 pm
    Because video at 24fps runs at 23.98. Only film, and high end cameras run at 24fps straight up. 24p video is 23.98…well, pardon, 23.976.
    Shane
    Little Frog Post
  • Robert Shanks
    January 13, 2016 at 1:14 am
    Thank you….any way to overcome sync issues from external recorded audio…thank you
    ROBERT SHANKS
  • Shane Ross
    January 13, 2016 at 1:51 am
    What was used to record audio? Did it record it at 44.1kHz, or 48kHz?
    Shane
    Little Frog Post
  • Robert Shanks
    January 13, 2016 at 2:06 am
    tascam 70d
    ROBERT SHANKS
  • Robert Shanks
    January 13, 2016 at 2:08 am
    44.1
    ROBERT SHANKS
  • Shane Ross
    January 13, 2016 at 2:10 am
    It should have been recorded at 48kHz. That’s what’s needed for video sync. You might be able to convert it after the fact and have it sync. Compressor can do this….there are presets.
    Shane
    Little Frog Post
  • Robert Shanks
    January 13, 2016 at 2:14 am
    convert the 23.976 video to 24p?
    ROBERT SHANKS
  • Shane Ross
    January 13, 2016 at 2:21 am
    No…that won’t do anything. The issue is that the audio is 44.1. It needs to be 48k.
    Shane
    Little Frog Post
  • Robert Shanks
    January 13, 2016 at 2:23 am
    ok…many thanks for ur help and patients…
    bob
    ROBERT SHANKS
