Activity › Forums › Adobe After Effects › Luminance Shifts out of AE
  • Luminance Shifts out of AE
    Posted by Aaron Barton on August 7, 2012 at 2:29 pm
    Hey Guys,
    So I was doing a comp in AE and everything looked fine and then I rendered it out (ProRes4444) and brought it into Final Cut and the footage was noticably darker. I then opened it up in Premiere and it was dark in there as well. I then set up a test and brought in a piece of footage to render out and see if I got the luminance shift again, but this time, no shift. Could it possibly be something in the comp that’s causing the shift or is it because I’m exporting out as a Quicktime?
    Aaron
    Tudor “ted” jelescu replied 14 years, 1 month ago 2 Members · 1 Reply
