Activity Forums Maxon Cinema 4D luminance lighting question
  • luminance lighting question
    Posted by Dan Mountford on June 17, 2011 at 8:00 pm
    Hello everyone.
    I am looking into trying to create lights that appear like the one seen in this https://vimeo.com/12177988.
    As you can see it is not a flat luminescent texture but is more like a faint gradient. is that all it is?
    Can anyone help me get lighting like this?
    Dan Mountford
    Adam Trachtenberg replied 15 years, 2 months ago 3 Members · 4 Replies
  • Greg Burrus
    June 17, 2011 at 8:59 pm
    Can’t say for sure but I did a quick little test and it looks like a Fresnel shader in the color and reflections give you similar look with something good for the reflections. It also looks like they took a lot of the saturation out of the image except for the color highlights,lens flare, and adding an overall blue hue.
  • Dan Mountford
    June 17, 2011 at 9:14 pm
    The top light looks like a gradient though in the luminance channel and I cant use both fresnel and gradient. Could the glow as well just be a post effect in after effects?
  • Greg Burrus
    June 17, 2011 at 9:55 pm
    The glow could be a post effect it would allow for more control. If you use a layer shader you can use any number of items on top of each other but it would be kind of redundant to use both maybe,
  • Adam Trachtenberg
    June 18, 2011 at 4:47 am
    Looks like post effects to me.
