Activity Forums Adobe After Effects luma shift while rendering DVCProHD in AE CS3
  • luma shift while rendering DVCProHD in AE CS3
    Posted by Dana Anderson on September 18, 2007 at 2:50 pm
    I just upgraded to Final Cut Pro HD 6 and After Effects CS3 and using Automatic Duck to export FC timelines to AE. While in AE, I can preview on my monitor using an AJA Kona LH and the color is well represented. However, when I render out a DVCPro HD 720p 60fps file, the color starts off great, then after rendering a few seconds, it appears that the luma suddenly drops resulting in a color shift. This has happened on several different compositions, so I know it’s not an accidental color correction or level keyframe change on my part.
    This never happened while using AE 7.0, but unfortunately I cannot go back to that version because I’ve already upgraded the project I’m working on to AE CS3.
    Has anyone else experienced this problem?
    Dana
    Matthew Gellert replied 18 years, 10 months ago 3 Members · 3 Replies
  • Mathieu
    November 12, 2007 at 9:43 am
    Hello,
    I’v the same issue whitin all QT format. When rendering TGA or else, the problem is not there !
    Thank You QT…. now the Q is how to get thru this….
  • Dana Anderson
    November 12, 2007 at 3:05 pm
    I’ve also noticed that this only happens when I’m using video clips inside of an AE Comp. I’m working on a project now that is strictly graphics – I’ve rendered to QT and it’s fine.
  • Matthew Gellert
    November 14, 2007 at 4:04 pm
    Bump. Having the same issue. Outputting DVCPRO50 and getting a chroma shift after a couple of seconds on all clips. The ingested footage is DVCPROHD, we are downrezzing to 4:3 sd. Has anyone solved this?
