Activity › Forums › Blackmagic Design › Luke, on that old Beta deck…
Posted by Chris Poisson on October 12, 2006 at 3:47 pmYour hunch was correct, I hooked up the DLSP to my monitor an voila, desktop was there, so I guess that old deck is not compatible.
Luke Maslen replied 19 years, 11 months ago 2 Members · 3 Replies -
Luke Maslen
October 13, 2006 at 5:45 amHi Chris,
I can’t find the post to which this refers. Can you give me the subject or a link to the old article?
Regards,
Luke Maslen
Blackmagic Design -
Chris Poisson
October 13, 2006 at 4:59 pm -
Luke Maslen
October 16, 2006 at 12:36 amHi Chris,
Thanks for the link. You mentioned that you can capture composite video plus analog audio from the old Sony BVW 25 and that you can also play video and audio from the deck to a video monitor and speakers. However when playing back video and audio from the timeline of Final Cut Pro, through the deck to the attached video monitor and speakers, you cannot see any video or hear any audio.
If you set the deck to record, and then play out from the Final Cut Pro timeline, is your video and audio recorded on tape even if you cannot monitor it via the deck’s video and audio outputs while recording? If so, then my suggestion would be to perform your monitoring via the spare DeckLink outputs while capturing from or playing back to the deck.
If you find that you cannot record to tape, then presumably there must be some setting in the deck that has to be changed, or else the deck is malfunctioning. Has this deck previously accepted composite video input via the Video In BNC port or has it only been used with the Camera input?
Regards,
Luke Maslen
Blackmagic Design
