Activity Forums Audio LUFS and Lex(m)
  • LUFS and Lex(m)
    Posted by Grzegorz Kwiatkowski on December 7, 2012 at 9:42 am
    Do you know if there is any VST plugin that measures LUFS and Lex(m)? There is The Waves WLM Loudness Meter plugin but it costs 400$.
    Chris Conlee replied 13 years, 5 months ago 4 Members · 4 Replies
  • Peter Groom
    December 7, 2012 at 5:19 pm
    have a look at NUGENs VisLM and lc
    Post Production Dubbing Mixer
  • Jean-christophe Boulay
    December 10, 2012 at 9:14 pm
    I second Peter’s suggestion. VisLM-C does a great job, is widely compatible and is cheaper than most other options. Plus, Nugen really have established themselves as the broadcast metering and limiting specialists and they closely follow each standards revision. Updates are online days after revision at the most, not weeks as with some other developers. Most other options are expensive, have limited compatibility depending on software versions or imply that you’re already drinking the developer’s authorization kool-aid.
    The VisLM-H version has histogram metering and data logging facilities the VisLM-C version lacks but, in my experience, The Compact version more that enough for almost all situations.
    IHTH
    JC Boulay
    Technical Director
    Audio Z
    Montreal, Canada
    http://www.audioz.com
  • Grzegorz Kwiatkowski
    December 13, 2012 at 12:04 pm
    But Nugens VisLM-H doesn’t measure Leq(m), does it?
  • Chris Conlee
    April 1, 2013 at 7:20 pm
    Did this ever get answered? I too am curious whether VisLM does Leq(m) metering. Also, does LM-Correct do Leq(m) corrections?
    Chris
