LTO – faster to archive audio than video files
We regularly write video, photo, and audio data to LTO tape. We recently noticed that when writing audio files, the tape write operation goes much faster. I am anxious to know why this is.
Note: We always write only one type of file to a particular tape (e.g. one LTO tape will contain only video files)
We’re using Tandberg LTO-4 SAS Half height standalone drives, and for a typical tape of 650GB photo or video it takes about 2hrs40min to write a tape (which works out to be around 70 mbps), but when we write audio files, the speed reaches around 110 mbps and for 650GB the job finishes in under 2 hrs.
We use BRU as our backup software – which we have been very happy with for the past 5 years. The only thing I can think of is that compression is being applied to the files, and the audio files (wav + mp3) are able to be compressed much more, and therefore it is actually writing less data.
However, we have not specified any compression options in the BRU config (since most of our data is video) we will not benefit from compression.
I’ve gone through our logs over the past 5 years (700+ tapes) – and checked the write and verify timings… and every time it as a tape containing audio files (15 tapes) I’m seeing the same thing.
If anyone can explain why this is happening, I would really appreciate knowing. As the drives have an advertised speed of 75mbps… if I’m sometimes getting 110 mbps then it feels like something odd is going on.
Kind Regards
Swami
