Activity Forums Apple Final Cut Pro Legacy lowering resolution of dpx to edit
  • lowering resolution of dpx to edit
    Posted by Mark Wales on April 1, 2008 at 11:11 pm
    My system 2GHZ processor, 6 gb memory, power mac G5 with 1Ghz bus speed, 7500rpm harddrive, using esata drives that are raided to store dpx files, final cut pro 6.0.2 and quicktime pro7.4.1
    My dpx files are 9.2 gb and brought in through an AJA plug-in which created a reference file. What are my options for making these workable low res files that I can also export later as high quality dpx files through the glue tools plug-in.
    Ben Scott replied 18 years, 5 months ago 3 Members · 2 Replies
  • Russell Lasson
    April 1, 2008 at 11:19 pm
    I would compress the AJA reference movies to DVCPROHD in compressor. Make sure to keep the names the same. Then when you’re ready, just reconnect the files to the AJA reference movies.
    -Russ
    Russell Lasson
    Kaleidoscope Pictures
    Provo, UT
  • Ben Scott
    April 2, 2008 at 12:20 pm
    why not prores thats proper HD and sq pixels unlike dvcpro hd?
    Check my podcast at https://cowcast.creativecow.net/final_cut_pro/index.html
    or my site at
    https://www.benscottarts.co.uk/ – – – – – – – – –
