Activity Forums Apple Final Cut Pro Legacy Lowering file size from FireWire import
  • Lowering file size from FireWire import
    Posted by Sharif Al-haj on June 12, 2012 at 4:44 pm
    I am going on a trip soon and need to figure this out ASAP. I am important an SDI feed via Firewire into Final Cup Pro “Log & Capture” Mode. I have 2 external 1.5 Terabyte hard drives with me to capture the footage directly onto there. However, testing this method out I have noticed that a 17 seconds video clip has cost me 114MB on the drive. At this rate I will only be able to capture 3min max before my 1.5 T drive becomes completely full.
    How do I lower the size of my input FireWire feed? without losing too much quality?
    Thank you!
    All the Best!
    Shane Ross replied 14 years, 3 months ago 2 Members · 1 Reply
  • Shane Ross
    June 12, 2012 at 4:57 pm
    [Sharif Al-Haj] “I am important an SDI feed via Firewire into Final Cup Pro”
    How? You must have a capture box or some converter in there. SDI and firewire are completely different connector types.
    [Sharif Al-Haj] “testing this method out I have noticed that a 17 seconds video clip has cost me 114MB on the drive. At this rate I will only be able to capture 3min max before my 1.5 T drive becomes completely full.”
    Your math is a little off. After MB comes GB (gigabytes)…and then TB (Terrabyes). You can capture a lot more than 3 min.
    If you are capturing via firewire, your options are DV and HDV…both are 13GB per hour. You can capture over 100 hours in those formats on that 1.5TB drive.
    Shane
    Little Frog Post
