Activity › Forums › Lighting Design › Lowell light repair
  • Lowell light repair
    Posted by Gary Carbo on June 21, 2012 at 5:48 am
    I’ve searched, but can’t find a Los Angeles area Lowell light repair shop, authorized or not. Any suggestions? Thanks in advance.
    Bob Cole replied 14 years, 3 months ago 4 Members · 8 Replies
  • 8 Replies
  • Mark Suszko
    June 21, 2012 at 4:38 pm
    What are you trying to repair? Might be you can DIY with parts from the factory.
  • Gary Carbo
    June 21, 2012 at 4:54 pm
    I don’t know. It just won’t power up.
  • Mark Suszko
    June 21, 2012 at 5:13 pm
    What model is it, and what have you checked so far? The bulb of course? What else?
  • Gary Carbo
    June 21, 2012 at 8:27 pm
    Omni, I changed the bulb, switched the power cords and finally opened it up. The wires look good (not frayed) Other than that nothing looks abnormal.
  • Mark Suszko
    June 21, 2012 at 9:34 pm
    I would next try yet another fresh bulb from another instrument in he kit, and if it still didn’t light, after changing our cords and switch, that just leaves the socket.
  • Scott Sheriff
    June 22, 2012 at 12:20 am
    Sounds like a bad socket. Lowel lights are meant to be field repaired. Probably a 15 minute job once you have the part in hand.
    Simple test is to check socket continuity with a known good bulb.
    First test the continuity of the test bulb out of the socket. They can have hairline cracks in the filament that can’t be seen, so test before to be sure and avoid false negatives. Avoid power cycle ‘hot testing’ lamps, since this only confirms it works now. It (the filament) could open when it cools off. A continuity test with a VOM is the way to go.
    Second, plug your known good bulb into the socket, and check the continuity from the power cord socket to the lamp socket. If there is no continuity or high resistance, replace the socket.
    Once lamp sockets start to get loose, they arc and pit the socket contacts, which in turn causes more looseness and so on…
    In an emergency sometimes it’s possible to get some life out of a dead socket by scraping the contacts with some type of improvised tool. In this case a tight fitting drill bit may work. Be sure that you are not powered up. If the socket is dead, it can’t make it worse. But it might give you a couple of hours. Maybe. Of course this is at your risk.
    Scott Sheriff
    Director
    https://www.sstdigitalmedia.com
    “If you think it’s expensive to hire a professional to do the job, wait until you hire an amateur.” —Red Adair
    Where were you on 6/21?
  • Gary Carbo
    June 22, 2012 at 4:12 am
    Thank you I’ll give it try.
  • Bob Cole
    June 29, 2012 at 5:31 pm
    Lowell is good about sending you the parts you’ll need.
