Activity Forums Adobe Premiere Pro Low system memory prompt….
  • Low system memory prompt….
    Posted by Rob Anderson on April 10, 2008 at 7:53 pm
    Just got a low system memory prompt from PP cs3 I have plenty of ram and lots of hard drive space…What would cause this?
    On a side note any advise on setting to get PP to run as effective as possible?
    Rob
    Ben Hawkins replied 18 years, 5 months ago 2 Members · 1 Reply
  • Ben Hawkins
    April 10, 2008 at 8:30 pm
    first, it might not be your ram. I got these same error messages as well and it turned out to be the size of the still images I was using.
    If you have images in your time line make sure they are not super hi-rez or 300 dpi, and I wound try to stick with Jpegs.
    If you are using images that are 300 dpi try bumping them down to 150.
    Also in your Preferences adobe recommends you change the setting optimize rendering for – “memory” but this means that when rendering Premiere will use as much memory as it can.
    So exit out of other programs 🙂
    Hope this helps!
    I got the hottest beats and the softest fur.
