Activity Forums Apple Final Cut Pro Legacy Low rezolution Exports in FCP
  • Low rezolution Exports in FCP
    Posted by Huffy Williams on October 28, 2010 at 10:21 am
    Hellow fellow Heffers!
    I’d like some advise on exporting low rez QT from FCP that will maintain the correct aspect ratio, and a relatively nice quality.
    My current project is 1440×1080 @ 25fps
    Andy George replied 15 years, 11 months ago 2 Members · 1 Reply
  • Andy George
    October 28, 2010 at 4:09 pm
    Hi Huffy,
    The footage your working with uses a non-square pixel aspect ratio. Unlike FCP Quicktime player will not handle a non-square pixel. So the key to getting the aspect ratio to appear correct is to convert it to a square pixel aspect ratio.
    Your 1440×1080 footage in square pixels works out to 1920×1080. If you want to make it smaller than that you can choose from any proportional size like 1280×720, 960×540, 640×360 ect.
    H.264 is a good choice for a codec if your not intending to edit these low-rez versions.
    At 640×360 you could get away with some pretty small rates. I would start at about 600-700kbps and move up from there until your happy with the picture vs size. At 960×540 I would start at around 1200kbps
    -Andy George
    Senior Editor
    http://www.chiselindustries.com
