Activity Forums Adobe Encore DVD Low quality in Adobe Encore
  • Low quality in Adobe Encore
    Posted by Sam Alderson on August 3, 2011 at 11:05 pm
    I have exported high quality (1920×1080 lossless) footage from Adobe After Effects. Now when I take it into Adobe Encore to make a DVD I find that it loses all its quality once it’s transcoded. Unless I burn it to blu-ray it can’t keep its original 1920×1080 size and I’ve tried many different transcode settings as well as exporting a mpg2-DVD from After Effects and it seems like none of them would look high quality on a television.
    Daniel Ludwig replied 15 years, 1 month ago 3 Members · 3 Replies
  • Eric Pautsch
    August 4, 2011 at 12:33 am
    DVD is 720×480 NTSC / 720X576 PAL.
  • Sam Alderson
    August 4, 2011 at 12:50 am
    But how does that work on a TV or even computer? It just doesn’t seem to produce high enough quality?
    I’m sorry for the stupid questions I am just confused.
  • Daniel Ludwig
    August 5, 2011 at 5:24 am
    Hey Sam,
    your eyes are irritated by the HD-picture. SD-picture allways looks like you have a big blur on the footage – compared to your original HD-quality.
    SD-DVD only allows 720×480 for NTSC or 720×576 resolution for PAL as eric discribed.
    and television/broadcast is working with the same resolutions. if you playback a DVD on a computer, it is the same – but most software-players scaleing the picture to full screen, and using no good scaling-allgorithms.
    you see there is no other way to go – if you would like to have better picture-quality on optical discs you need to go blu-ray.
    cheers
    danny
