Activity Forums Blackmagic Design Low quality from component out
  • Low quality from component out
    Posted by Ben Hendriks on October 2, 2010 at 2:58 pm
    After a dead RS422 port on my Decklink studio, I now have a brand new
    card.(thanks to BM England and Mediamachine (Holland)
    But……….My old card showed a very low quality from the component
    output, a bit like a 256 color image(only in HD). After a cold start the image was ok, but over time it turned into this cartoon like image.
    I was very supprised to see that the brandnew and tested card is even worse!!HD component is very bad! Same as mentioned above. Cold start OK,degrades over time.
    It is hard to believe the new card has the same problem as the old one.I checked my cables and the monitor with a different source, OK.
    So, a problem with my logic board? PCI slot? I have no idea.
    any thoughts?
    Best Ben
    Ben Hendriks replied 15 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
