Activity › Forums › Adobe After Effects › Low memory warning
  • Low memory warning
    Posted by Giuseppe Cacciola on October 19, 2022 at 9:57 am
    Hi! I have a 2019 macbook pro with 16 gb ram. Yesterday, even with the most simple composition (just a shape going from a A point to B) i can’t see the preview and this message says “low memory warning. RAM use has been extended for previews. Adjust Ram settings in preferences-Memory and Performance”. The thing is that ALL of the memory is reserved for After effects (13 gb/16). Of course i purged memory and caches several times, but nothing changed. I saw soooo many tutorials saying the same things but nothing… What can I do? Thank you so much
    Graham Quince replied 3 years, 11 months ago 2 Members · 1 Reply
  • Graham Quince
    October 22, 2022 at 12:08 pm
    Unfortunately, 16Gb is now the minimum required to run AE, so these errors might become more common for you. That being said, I have seen a few posts complaining about a potential bug that Adobe are looking at around previews on mac.
    It might be connected to your graphics card. What happens if you switch to Software only in Project Settings?
