Activity Forums Adobe Premiere Pro Low Lighting Footage
  • Low Lighting Footage
    Posted by Howard Mills on March 4, 2008 at 1:31 pm
    Hello, I would first like to thank you for taking the time to read my post and for trying to help. My problem is I shot about two hours of video last night which came out dark. It was indoors and the lighting was ok when I started but deteriorated as the evening got later. Is there some setting to bring the darker portion as close as possible to the not so dark footage? I’m using PP2.
    Thank you
    Dell XPS 400,
    2.80 MHZ,
    1 GB Ram,
    2-160 GB HD,
    Lacie 500GB Externel Firewire HD
    Win XP Pro SP2,
    Canon XL1,
    JVC-BR- DV3000U,
    Howard Mills replied 18 years, 6 months ago 5 Members · 6 Replies
  • Steven L. gotz
    March 4, 2008 at 5:12 pm
    Start by working with the Levels effect. It will get more grain in the footage, but there is no other way to really deal with the issue other than to make the adjustments.
    Steven
    https://www.stevengotz.com
  • Howard Mills
    March 4, 2008 at 5:39 pm
    Steven, you’re absolutely right, the footage does display more grain. I was hoping there was a easy way to fix this but I guess in the future I need to shoot with better lighting.
    Thank you,
    Howard
    Dell XPS 400,
    2.80 MHZ,
    1 GB Ram,
    2-160 GB HD,
    Win XP Pro SP2,
    Canon XL1,
    JVC-BR- DV3000U,
  • Jan Janowski
    March 4, 2008 at 6:12 pm
    Try Shadows/Highlights
    That was made for that type of video.
    Looking for 1939 Indian Motocycle
  • Mike Velte
    March 4, 2008 at 7:26 pm
    Often video appears darker on a PC monitor than it actually is…make your adjustment and preview on a TV if your target is DVD.
    https://www.video2stream.com
  • Bart Straman
    March 5, 2008 at 9:46 am
    hi, you can blur your footage with minimum values to get rid of the most obvious grain you see. (donno if that’s possible in PP2, but it must be). In After effects, yeah, use levels, curves etc all works well for low lights
    Ultimate Bart
    Artmedia Designs
  • Howard Mills
    March 5, 2008 at 7:23 pm
    I really appreciate all the input.
    Thank you.
    Howard
    Dell XPS 400,
    2.80 MHZ,
    1 GB Ram,
    2-160 GB HD,
    Win XP Pro SP2,
    Canon XL1,
    JVC-BR- DV3000U,
