Activity Forums Apple Final Cut Pro Legacy Low image quality in timeline
  • Low image quality in timeline
    Posted by Steve Clark on April 5, 2010 at 4:00 pm
    When I drag a perfectly sharp scene from one timeline to another, the image quality diminishes dramatically even after rendering. This doesn’t happen when dragging to the 2nd timeline where the clip is color corrected and modified, but usually the third where I put the best takes. Any suggestions?
    Steve
    David Roth weiss replied 16 years, 5 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    April 5, 2010 at 4:42 pm
    Sounds like your sequence settings don’t match from sequence to sequence… they need to be the same.
    Or I’d just create bins for your selects instead of sequences.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • David Roth weiss
    April 5, 2010 at 4:57 pm
    Typically when starting a new project the sequence settings in the existing Seq. 1 that is already open in the browser will not wind up with the sequence settings that you establish using an Easy Setup. All new seqs. that you open will, so it’s very possible that you have wrong settings in just one of your seqs.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
