Activity › Forums › Field Production › Low cost, HD field monitor
  • Low cost, HD field monitor
    Posted by Justin Toops on November 14, 2010 at 1:47 pm
    I have a Sony Z7U, and would like to add a HD field monitor for under $1000. Two that I have looked at are the Ikan 8″, and the Manhatten LCD HD089B-S 8.9″.
    Does anyone have a recommendation on these, or can weigh in on a low cost field monitor that they love?
    Stephen Mann replied 15 years, 10 months ago 3 Members · 2 Replies
  • Bob Cole
    November 15, 2010 at 9:35 pm
    I like the 6.5″ Marshalls at about $1600. I’m sure a great sub-$1000 monitor is possible, but I didn’t get to test either of the models you mentioned. I did see some nameless monitors that were terrible in that sub-$1000 range.
    I feel your confusion — just went through it myself. There are so many criteria, and you need to figure out which matter most to you. You need to clarify why you want a monitor. Is it for focus? Composition? Client involvement?
    You would be very well-advised to try monitors out in person. A monitor could be perfect for one application and terrible for yours. For example, a studio shoot would be a fine place for a heavy, high-resolution monitor — but if you’re running around locations single-handed, you’ll want something lightweight. Powering options are another consideration; a battery can change the whole configuration dramatically.
    For me the criteria were a reasonably clean image; optional pixel-to-pixel monitoring; light weight; reputation of manufacturer; flexibility of powering. Incidentally, I found that most mounts were too weak – I wound up buying a sturdy little Manfrotto ball-head which screwed into my camera’s hot-shoe.
    Good luck and let us know what you find.
  • Stephen Mann
    November 20, 2010 at 3:15 am
    I am using the LCD4Video.com 7-inch HDTV monitor on my Sony Z1’s. They were $250 on the NAB floor, and once in a while you an get them for that on their site. The monitor is pretty good for what it is. Much sharper than the cheap “security cam” moitors for $150. It is missing some of the high-end features of the $1600 monitors, but if all you need is a larger screen for framing, then this is it.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
