Activity › Forums › Apple Final Cut Pro › Loving using compound clips in FCPX
  • Loving using compound clips in FCPX
    Posted by Noam Kroll on March 6, 2012 at 4:22 pm
    After using FCP X since it launched in June, I am still learning the benefits of it’s feature set. For a recent promo video I did, I decided as a test to cut a version in FCP 7 and then in FCP X. I didn’t end up even getting through the cut on FCP 7, because I was flying through the edit so much more quickly in X.
    The main reason I was able to speed things up so quickly was through the use of compound clips. I mention this just because I would assume many users (including myself at one point), know what these basic new features are, but are not fully embracing them. When you try to make X work like 7, it feels awkward. But when you go with it and use the tools how they should be, it is really quite amazing.
    Check it out if you’re interested: https://vimeo.com/38031045
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Mark Morache replied 14 years, 6 months ago 4 Members · 3 Replies
