Activity Forums Adobe Premiere Pro Loud audio feedback on playback of cross fade (sequence imported from FCP 7)
  • Loud audio feedback on playback of cross fade (sequence imported from FCP 7)
    Posted by Crescent Diamond on May 26, 2016 at 5:32 pm
    Hey all. So I exported a 90 min sequence from FCP 7 (had to do it in chunks) but eventually got the whole thing in Premiere Pro CC 2015 (9.2.0).
    Problem is: loud feedback when playing back audio Constant Power cross fades, but not every time, if I go back to spot after playing it and play again, the feedback SOMETIMES does not play. When I delete the crossfade, the feedback does not play but when I add a new crossfade (Constant or Exponential) in Premiere, it plays again.
    What I’ve tried:
    -created a new sequence in Premiere and copied and pasted
    -deleted render files
    -rendered audio
    -deleted media cache
    There are no audio plugin effects or any effects except volume on these clips besides the fade.
    Also to note: I edit projects that originate in Premiere every day all day and have not encountered this particular problem with any other project. No help from Adobe Support.
    System info:
    Thanks, Crescent D.
    Crescent Diamond replied 10 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
