Activity Forums Adobe After Effects lots of text?
  • lots of text?
    Posted by Servet Bay on August 26, 2007 at 11:16 am
    hi everybody..i have a problem with texts..like this…i am making a project which should include a lot of texts with effects…aproximately there will be more than 70 texts…it means many text layers as you realize…should i make it in different comp or in the same comp….is it a problem making a comp has over than 100 objects…how can i work useful…
    Mike Clasby replied 19 years ago 2 Members · 1 Reply
  • Mike Clasby
    August 26, 2007 at 8:29 pm
    No problem with have a hundred layer, some have many more. The bigger problem oftern is keeping things organized and being able to find things. Often that’s another reason to precomp.
    Is it possible to do what you want with a particle generator with text as particles? Sometimes one layer can generate what appers to be hundreds, thousands.
