Lots of SD to 1080/23.98
Ok my fellow Kona Cows: need some advice
working at a new facility. booked an online with some old clients. 80% of the film is either HDCAM 1080/23.98 or P2 @ 720/23.98. 20% of the film is stock footage – digi, beta SP, and some DVD.
My plan is to finish in 1080/23.98 – the P2 footage will upscale beautifully with the Kona 3. But what can I do with all that SD? Time is a problem: we can only book 2 days.
My initial thought is to run all the SD footage through a Snell&Wilcox HD6200 box to upconvert it to 1080 – however I’m unfamilar with the gear and don’t know if it will auto dectect 3:2 cadence and adjust dynamically. I’ve never tried to upscale SD with 3:2 to HD with the Kona 3 – but can it do 3:2 removal well or at all?
Any other options if you’re facing 10-12 miunutes of SD footage that needs to be made into 1080/23.98 on a severe time budget?
