Activity Forums Adobe After Effects lots of compositions?
  • lots of compositions?
    Posted by Servet Bay on December 11, 2007 at 5:28 pm
    hi everybody…i’ve a problem like this…i am preparing a beginning of a movie…i found a texttosand project file in the internet…but there is a problem…this project file includes 3 compositions with main one…my project will be like that the text is “directed by serwet”…then it turns into sand ..”written by harun”…then turns into sand,too..i mean there will be many writings in my project…probably you’ll understand the problem.texts changes many times.if i change anyone i dont want to effect the others..but i cannot do that until now..the texttosand prj file(as i said before includes 3 comps with text comps)so i have to use it many times so there will be lots of comps,right?
    how can i avoid this…
    Servet Bay replied 18 years, 9 months ago 19,278 Members · 1 Reply
  • Servet Bay
    December 14, 2007 at 1:09 pm
    thank you dave…i figured out a solution like that i render the texttosand comp as a mov file and import the files.i did this 10 times…if i would do that in old way that i tried..it would be many compositions…this is the easiest way i found…
