Activity Forums Adobe Premiere Pro Lost time code on source clips– PP Capture accuracy
  • Lost time code on source clips– PP Capture accuracy
    Posted by Richard Milner on September 23, 2005 at 7:30 pm
    we had a drive stack that we transfered from one computer to another. After a crash, we lost time code in the project window. All clips start with 00:00:00. When you go into the properties of the clips, it has the starting timecode number.
    Any ideas how to get the TC back?
    Also, why isn’t PP capture frame accurate when capturing? We captured clips 3 times, and it was off as much as 5 frames.
    Ngocth replied 21 years ago 2 Members · 1 Reply
  • Ngocth
    September 25, 2005 at 11:38 am
    I have a problem when capture in Premeiere Pro 1.5 with matrox RTX100 card. When I finish capture, the duration of clips in timeline window is longer than the duration of clips in capture window. Example: I capture with the duration 20 minutes but the duration in timeline is 24 minutes. Please help me quickly. Thanhks for support!
