Activity › Forums › Adobe After Effects › Lost the ‘Make Movie’ controls
Posted by Sean Winn on November 13, 2012 at 8:32 pmHi,
Cleaned up our system yesterday and today, when trying to save out a composition (make movie), it’s jumping right to the system location box and no longer have the settings options in the render queue (where I can change to h.264, pro res, etc).Tried resetting preferences on a restart, but it’s still behaving the same way.
Thanks for any assistance.
SeanTodd Kopriva replied 13 years, 10 months ago 3 Members · 8 Replies -
Kevin Camp
November 13, 2012 at 9:12 pmso there are no options to select in the output module in the render queue?
i’d try holding cmd-opt-shift (osx) or ctrl-alt-shift (win) when starting ae. it should ask if you want to reset the prefs file, click ok — note this will reset your prefs file to the default install settings, so you may need to set some setting back… like cache directories, multiprocessing, memory and third-party i/o card settings.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Sean Winn
November 13, 2012 at 9:25 pmYes, did that on the preference reset (cmd option shift), but no change when saving out. You hit ‘make movie’ and a save to dialogue box appears. If I close that out, down in the render queue and go to output module, usually I’m able to click ‘lossless’ and choose my settings in the resulting dialogue. Now, it’s not active.
Normally, you choose make movie and the render queue pops up and you select your settings and the save. So, hmmm, not sure what’s gotten out of whack here. Appreciate any further help.
Kevin Camp
November 13, 2012 at 11:09 pm[Sean Winn] “Yes, did that on the preference reset”
sorry i should have read your original post more closely…
i assume you have the same problem if you choose composition>add to render queue…?
you could try moving the entire preference folder out to the desktop.
in osx you’d find it in users/[username]/library/preferences/adobe/after effects. quit ae and try moving the entire folder that has the version number on it to the desktop, then restart ae.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Sean Winn
November 13, 2012 at 11:16 pmHi Kevin,
Thanks for the response. Well, that worked (composition – add to reder queue. Never used that before, so didn’t dawn on me. Not sure why the make movie dialogue has changed, but won’t matter as long as this works. Appreciate the time,
Sean -
Todd Kopriva
November 13, 2012 at 11:17 pmIt sounds like what you’re seeing is the expected behavior: The first time that you use Make Movie, a dialog box appears to ask what your target location is for output files. After that first time, the dialog box no longer appears because After Effects assumes that you always want to begin with that as your target location.
If you’re just closing that dialog box without indicating a target location, then you don’t add the item to the render queue.
BTW, this is one of the reasons that we removed the Make Movie command from After Effects CS6. For many years, the Add To Render Queue command has been a much better choice, with more functionality and fewer chances for confusion like this.
After Effects team blog
Sean Winn
November 13, 2012 at 11:19 pmOk, sweet, that explains it perfectly. So, even though I’m still on CS5, I’ll start using the ‘add to’ function.
Again, thank everyone for their time.
Sean -
Kevin Camp
November 14, 2012 at 4:12 pm[Todd Kopriva] “It sounds like what you’re seeing is the expected behavior”
sorry sean, i sent you on a bit of a wild goose chase… i had never used the make movie method, i had always thought that behaved the same as add to render queue, and that’s the method i’ve always used.
i had wondered why there were 2 options that did the same thing (or nearly) but had never looked into the difference.
thanks todd
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Todd Kopriva
November 14, 2012 at 7:50 pm> i had wondered why there were 2 options that did the same thing (or nearly)…
Me, too. That’s why I had the lesser alternative removed in After Effects CS6. It was just confusing people.
> thanks todd
No problem. Just doing my job.
