Activity › Forums › Apple Final Cut Pro Legacy › lost reel nos
  • Posted by Sean Davison on December 5, 2007 at 11:18 am
    Ive just started redigitising an offline project at full HD Res and as FCP captures clips the reel number vanishes from the Browser – Any one know why this is? is it safe to carry on (Im on a tight deadline here!)
    I need to put this into color to grade and back to FCP….Im scared!
    Jeremy Garchow replied 18 years, 10 months ago 4 Members · 9 Replies
  • 9 Replies
  • Bouncing Account needs new email address
    December 5, 2007 at 3:16 pm
    Save your work.
    The first thing to always try is to Quit FCP, Restart the Mac, Open your FCP project and try again.
    Next:
    THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
    “Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”
    Click the following link for instructions.
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
    There are versions for FCP (Pro) & FCE (Express) and a new one for FCP 5.
    Download these free Apple Scripts at
    https://fcprescue.andersholck.com/
    or
    https://pistolerapost2.com/fcprescue/
    This is one FCP tip that has helped in solving hundreds of “odd” problems.
  • Sean Davison
    December 5, 2007 at 4:18 pm
    Thanks – Trashing the prefs works but wont bring my reel nos back – THIS IS A REALLY SERIOUS BUG!!!!!!!!
    I had an assistant digitising a project overnight (200+tapes) I have just had to start again.
  • Bob Flood
    December 5, 2007 at 4:31 pm
    sean
    are you digitizing to the Apple Intermediate codec? this codec will let you work faster with HDV material you capture via firewire, but you lose the original time code and reel information.
    in essence it makes each capture a quicktime with no metadata.
    it has become obsolete with the release of pro res
    hope this helps
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
  • Sean Davison
    December 5, 2007 at 4:36 pm
    No we’re capturing using the DVCProHD codec 1080i50
    S
  • Jeremy Garchow
    December 5, 2007 at 4:42 pm
    Did you get a warning about capturing drop frame material into non drop media or vice versa?
  • Sean Davison
    December 5, 2007 at 5:42 pm
    No – Its almost certainly a bug – I trashed the prefs and started again and all is fine -i just lost 8 hours work though!
  • Jeremy Garchow
    December 5, 2007 at 5:46 pm
    Is it only the reel numbers or is it all logging info?
    Reel numbers are easy to rename.
  • Sean Davison
    December 6, 2007 at 8:47 am
    reel nos and timecodes! Bummer eh?
  • Jeremy Garchow
    December 6, 2007 at 4:42 pm
    Total bummer.
    I have seen this before, and it had to do with Drop and non drop timecodes and capturing of the wrong one. (I know, you are in the Land of PAL so that stuff doesn’t matter to you), but it got me thinking. Perhaps your assistant logged under the wrong Easy setup and when you went to capture, FCP got confused? Just a thought. Like I said, this bit me hard one time when capturing NDF DV, but it was logged using DF. I was never really sure what the hell was going on, but once I got all the timecode straightened out, the capture was successful (I had a copy of the project before capturing with all the timecode info in tact thankfully).
    You said this was an online, how was the offline captured?
    Jeremy
