Activity › Forums › Apple Motion › lost particle emitters,, replicaors, shapes, gradients from library
  • lost particle emitters,, replicaors, shapes, gradients from library
    Posted by Barbara Johnson on October 29, 2005 at 2:08 pm
    In a dazed 2 AM mind, I did something that affected the path, and now in the library, all the other goodies are there, but not those listed above. I can find the ones i have looked for in the hard drive, but dont know how i coud use them within motion. should i uninstal and reinstall Motion, or is there a way to get these goodies in order.
    Thank you, thank you
    Barbara
    Barbara Johnson replied 20 years, 11 months ago 2 Members · 2 Replies
  • Jim Kanter
    October 29, 2005 at 2:51 pm
    Library folder path is set in the application Preferences.
    Make sure everything is in there and then point Motion at the main folder. The default is under USERS > SHARED > MOTION > LIBRARY on the main system drive.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Barbara Johnson
    November 1, 2005 at 4:06 am
    Thank you, thank you. I should never play with my computer in the middle of the night…I should never…..
    Thanks again
    Barbara
