Activity Forums Apple Final Cut Pro Legacy Lost Monitor in FCP
  • Lost Monitor in FCP
    Posted by Matt Torti on May 21, 2009 at 2:20 pm
    I’m having problems concerning my external monitor hooked up to my editing system. I recently needed to change the settings for the video playback to a higher resolution to view in full frame. When I switched the settings back to the Blackmagic NTSC – 10 bit (720×486) it was at initially I lost the ability to preview in my external monitor.
    I have tried switching the settings for the video playback and the AV devices to pretty much everything that is offered, but I have had no luck regaining video – short of previewing another edit system on the monitor, so its definitely an error in FCP and not something with the cable or the monitor itself. I have tried exporting the video to other monitors, as well as laying off to tape on dgibeta, but everything is without picture.
    Are there presets I need to delete to regain video? I know this is a popular option for fixing FCP errors. Anything I can do short of a reinstall?
    Matt Torti replied 17 years, 3 months ago 2 Members · 2 Replies
  • Matt Torti
    May 21, 2009 at 2:49 pm
    I’d say I had a senior moment there, but I way too young for that slip. Thanks for the help John. You fixed to problem 100%
  • John Fishback
    May 21, 2009 at 2:54 pm
    Make sure in the View menu, External Video you have All Frames selected.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
