Activity Forums Panasonic Cameras LOST LASTCLIP.TXT (aka can’t believe it happened to me)
  • LOST LASTCLIP.TXT (aka can’t believe it happened to me)
    Posted by No1115 on February 11, 2007 at 8:12 pm
    YUP – it’s happened…
    Somehow, someway, the lastclip.txt got separated from the contents of one of my reels.
    Am using: FCP 5.1.2, MacBookPro and P2 Genie.
    Anyways I am trying to remarry them so I can import them.
    Tried rebuilding .txt using TextEdit using the three line method:
    Line one: the last modified clip (in my case 0004FF)
    Line two: 1.0
    Line three: number of clips + 1 (in my case 5)
    But the result I am always getting is:
    __________ (the folder I’m trying to import) has an invalid directory structure. Please choose a folder whose directory structure matches the supported media.
    Don’t know what this means – or what I’m doing wrong.
    Everything seems in order…….
    Any thoughts?
    John Mckeown replied 17 years, 8 months ago 4 Members · 3 Replies
  • Shane Ross
    February 12, 2007 at 2:11 am
    You don’t need it REALLY to import. Try…I have had success in doing so without it a few times.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Barry Green
    February 12, 2007 at 8:01 am
    If it turns out that for whatever reason you just can’t import it no matter what, you can try P2 Log Pro from Imagine Software; it has P2 Repair features for situations exactly like this.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • John Mckeown
    December 17, 2008 at 10:46 am
    Hi
    Although aware of the importance of the lastclip.txt, it slipped my mind when shooting on HVX-200 recently. I backed off my footage on the P2 onto a Sonnet Fusion F2 via my MacBook Pro, using Panasonic’s P2CMS and now when I come to use the footage, there isn’t a lastclip.txt file in any of the folders I created on the hard drives. Consequently, I can’t import into Final Cut Pro 6.
    Can anyone throw any light on what I’ve done wrong?
