Activity Forums Adobe Premiere Pro Lost in the Preset World…Which to use with Sony DSLR
  • Lost in the Preset World…Which to use with Sony DSLR
    Posted by Annabell Flood on April 30, 2013 at 1:12 am
    Hello All,
    I’d like to use AP CS 5.5 to make a DVD of my trip to Africa. I “filmed” using a Sony Alpha SLT-A65 DSLR. When I “get info” on my video clips I see the following:
    Codec: H264 – MPEG-4 AVC (part 10)(h264)
    Resolution: 1920×1080
    Frame Rate: 59.940060
    Decoded Format: Planar 4:2:0 YUV
    I think I’d like the DVD to be HD and Progressive. But, I’m at a loss to understand what Preset I should use when creating my AP Project.
    If anyone has a suggestion I would appreciate it.
    Thanks so much,
    -Annabell
    Ivan Myles replied 13 years, 4 months ago 2 Members · 1 Reply
  • Ivan Myles
    April 30, 2013 at 2:12 pm
    There are a few ways to create a sequence that matches your source footage:
  • In the Project panel, drag the source file onto the New Item icon at the bottom of the panel, or
  • In the Project panel, right click the source file and select “New Sequence from Clip,” or
  • In the Project panel, highlight the source file and select File > New > Sequence from Clip, or
  • Select File > New > Sequence > Custom Settings, and set the parameters to match your footage — Editing Mode: Desktop or Custom (I’m not sure which on CS5.5 uses), 59.94 fps, 1920×1080, Square Pixels (1.0), No Fields (Progressive Scan); audio will typically be 48kHz or 44.1kHz, and the other settings can be left as default
  • For more information and tutorial videos please refer to the discussion: Creating and changing sequences.
