Activity Forums Apple Final Cut Pro Legacy lost file extension on external
  • lost file extension on external
    Posted by Andy Shnikes on April 9, 2008 at 12:55 pm
    I backed up my final cut pro 4 quicktime files in final cut pro format on my external usb drive, and somehow the extension got deleted. The files are still there, but not final cut pro files i suppose. I cant even import them into final cut. They have no extension at all.
    Any suggestions?
    David Bogie replied 18 years, 5 months ago 3 Members · 4 Replies
  • Jerry Hofmann
    April 9, 2008 at 1:22 pm
    Tried adding an extension to their name? .mov should be correct. But *my guess* is that this isn’t the problem. If you dragged and dropped them during your backup, they may have been corrupted. Especially if the USB drive wasn’t formatted Mac OS Extended.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Andy Shnikes
    April 9, 2008 at 1:42 pm
    I can add the .mov ext. but that just turns it into a quicktime movie. it was a fcp file before. im not sure what happened, cause up until a few days ago all these files were .fcp files, maybe my external got abruptly disconnected, and these files were corrupted
  • Jerry Hofmann
    April 9, 2008 at 2:58 pm
    These are media files? they wouldn’t have a .fcp extention…. only project files have that.
    It will not change the file to add the .mov BTW… FCP movies and QT movies are the same thing. Just use a different application icon. Either should open in QT player.
    If you can’t open them in QuickTime, you have a problem… if you can but not import them in FCP you have a different problem.
    How did you export them from FCP? what codec were they before and after you’ve exported them?
    Jerry
  • David Bogie
    April 9, 2008 at 3:58 pm
    You may have simply turned off “show extension” (or is turned on “hide extension”?) in the view options for the drive.
    bogiesan
