Activity Forums Apple Final Cut Pro Legacy Lost clip names, replaced with ‘whoosh’?
  • Lost clip names, replaced with ‘whoosh’?
    Posted by Sarah Bright on April 22, 2010 at 12:10 pm
    Currently having an issue with FCP 7.
    Recently during an edit, it removed all clip names in the timeline (only in the timeline), when telling it to ‘show video clip names’ it named every clip ‘whoosh’.
    When right clicking and selecting ‘reconnect media’, it shows you the actual name of the clip. So, it knows the real name but for some reason everything is still named whoosh.
    Also, when exporting an EDL or XML, the clips names are, again, fine.
    This is causing a problem as we need to conform and offline.
    Any ideas??
    John Fishback
    replied 16 years, 4 months ago
    2 Members · 1 Reply
  • John Fishback
    April 22, 2010 at 2:57 pm
    If you edited a portion of a long clip to the timeline and renamed it Whoosh, all clips derived from that longer clip would also be renamed, unless you made Whoosh an Independent Clip.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
