Activity Forums Adobe After Effects Lossless Compression
  • Lossless Compression
    Posted by Stefan Rochfort on August 24, 2005 at 4:57 am
    I’m wanting to store working files (i.e. raw and intermediate footage) with lossless compression to save disk space. To date I’ve been using no compression due to fear of any codec losing information even if set to 100%/best quality. Can anyone suggest the best codec and settings to save files with lossless compression?
    Thanks in advance for your assistance in this.
    Steve Roberts replied 21 years, 1 month ago 7 Members · 7 Replies
  • 7 Replies
  • Michael Duff
    August 24, 2005 at 7:05 am
    how much footage are we talking about? I use QT animation codec…files are still pretty big….but then again, I’m backing up 30second TVCs.
  • Angus Mackay
    August 24, 2005 at 8:48 am
    If your using QT then the Annimation Codec is probably the default choice. However the best choice is probably Digital Anarchy’s Microcosm which has 16bit colour depth and incredibly small file sizes. To find out more about Microcosm check out
    http://www.digitalanarchy.com
    HTH
    Angus
  • Chris Zwar
    August 24, 2005 at 8:58 am
    The animation codec at 100% is lossless, and supports an alpha channel. But the compression is fairly limited and so the file sizes are really big, depending on your image content.
    The JPEG codecs- Photo JPEG & Motion JPEG, are practically lossless at 100% and will be about 1/3 the size of the same files compressed with animation. There will be some very minor rounding errors but no actual compression artefacts. Certainly nothing visible. However they do not support an alpha channel.
    If you are totally utterly and completely anal about preserving image quality then the animation codec is your best bet. Otherwise, if you don’t need an alpha channel, Photo JPEG or Motion JPEG will save you about 3 times the disk space. In all cases, you need to have the quality set to 100%.
    Personally, I use Photo JPEG at 100% whenever possible, otherwise it’s animation for anything with an alpha.
    These codecs are Quicktime based and cross platform.
    -Chris Zwar
  • Bill Clotz
    August 24, 2005 at 4:22 pm
    If you use avi, then I would suggest the lagarith codec: https://lags.leetcode.net/codec.html
    It gets excellent compression and even supports an alpha channel. It supports 8-bit RGB32 colorspace (the standard colorspace used by After Effects), although it does not support the 16-bit RGB colorspace.
  • Ryan Wieber
    August 24, 2005 at 5:01 pm
    Another option is to encode in QuickTime with the PNG codec, which was made speficially to be a widely-compatible, fully lossless compression format.
  • Stefan Rochfort
    August 24, 2005 at 11:25 pm
    Excellent, looks like photojpg is ideal for my needs. Many thanks for your help. Just one question on photojpg – I’m assuming that if I’ve got multiple generations of compression (i.e. I use one compressed mov in a composition which is again compressed using photojpg for the output and so on) I presume I’ll be compounding compression/rounding errors. Any idea how many generations at a 100% before you get visible degradation (to the very anal)?
    Thanks again.
  • Steve Roberts
    August 25, 2005 at 12:13 am
    You can test this by making multiple renders, recompressing, then placing the original render and the last render into a comp and comparing. You could mask half of one render or you could set the transfer mode of the upper layer to “difference”. In the latter setup, identical pixels would be black, non-identical pixels would show as a colour. The more black, the less degradation.
    Steve
