Activity › Forums › Adobe Premiere Pro › Loss of audio between Premiere and Encore
  • Loss of audio between Premiere and Encore
    Posted by Cath Prescott on August 6, 2009 at 1:40 pm
    Hi. I’m working with m2ts files in Premiere CS4. Premiere doesn’t have an issue with these files, and my audio plays perfectly within Premiere. However, when I export to Encore CS4 it doesn’t play the audio. I’m wanting to start using Encore on a regular basis to create DVD’s and Blu-ray discs, but I don’t see how I can do this if my audio won’t play in Encore. Am I doing something wrong? As an after thought, can I export to Media Encoder and THEN import the encoded file into Encore, or doesn’t it work like that? Whatever happens, I don’t want to lose any video or audio quality.
    Thanks in advance.
    Cath Prescott replied 17 years, 1 month ago 2 Members · 2 Replies
  • Mike Cohen
    August 6, 2009 at 2:38 pm
    I ALWAYS export to MPEG2 / WAV from Premiere and then import those into Encore.
    That wat you know what you have before Encore. It has to encode at some point, so it is not really a time savings to go from Premiere directly to Encore – that just offsets the encoding to a different place in time.
    Mike Cohen
  • Cath Prescott
    August 6, 2009 at 4:13 pm
    Thank you SO much, it worked! I now have my video AND audio in Encore and there is no loss of quality.
