Activity Forums Adobe Premiere Pro Losing Video in Premiere CS4
  • Losing Video in Premiere CS4
    Posted by Keith Emroll on April 5, 2011 at 12:06 am
    Hello!
    I recently obtained footage from a videographer who was shooting a live event for me. She shot on miniDV tapes and captured the footage into Final Cut. Since I’m using Premiere Pro CS4, she converted the footage into .AVI files for me within Final Cut and sent them to me on CDs.
    After transferring the .AVI files to my computer, I’ve noticed that when I open them directly, they play in Windows Media Player just fine. But when I import them into Premiere, I only get the audio. The video is not present – it’s just like importing an MP3 file.
    Does anyone know what may be causing this and what can be done to fix it? Does she have to do something in the conversion process, or is it a setting on my end?
    Keith
    Vince Becquiot replied 15 years, 5 months ago 2 Members · 5 Replies
  • Vince Becquiot
    April 6, 2011 at 5:21 am
    Hi Keith,
    If you right click on the clip and hit properties, what does it say about the video format?
    What codec did she use for export?
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Keith Emroll
    April 6, 2011 at 9:50 am
    Hi Vince.
    I’m not sure what codec she used for export. I’ll check with her. Meanwhile, here are the Properties:
    File Path: E:WCBF 2011 – Sat 8pmRaw FootageAli Clayton- Closeup.avi
    Type: AVI Movie
    File Size: 1.5 GB
    Image Size: 853 x 480
    Pixel Depth: 32
    Frame Rate: 29.97
    Source Audio Format: 22050 Hz – 16 bit – Mono
    Project Audio Format: 22050 Hz – 32 bit floating point – Mono
    Total Duration: 00;07;15;08
    Average Data Rate: 3.5 MB / second
    Pixel Aspect Ratio: 1.2121
    AVI File details:
    Contains 1 video track(s) and 1 audio track(s).
    Interleave: 1 : 1.00
    Video track 1:
    Size is 1.45G bytes (average frame = 118.62K bytes)
    There are 13044 keyframes.
    Frame rate is 29.97 fps
    Frame size is 720 x 480
    Depth is 24 bits.
    Audio track 1:
    Size is 18.30M bytes
    Rate is 22050 samples/sec
    Sample size is 16 bits
  • Vince Becquiot
    April 6, 2011 at 2:39 pm
    H Keith,
    It doesn’t look like it’s uncompressed, but at this point, I’d ask for either Quicktime Animation, Motion Jpeg, or PNG. The size will be smaller, and they all work cross platform.
    Vince Becquiot
    Kaptis Studios
  • Keith Emroll
    April 6, 2011 at 2:58 pm
    Right now, I’m having her send me the original tapes so I can capture them directly into Premiere. But I will keep this in mind for future reference. Thanks!
    By the way, do you know if there are ways to modify the presets for a sequence? There are numerous pre-sets to choose from, but have you ever been in a situation where you’ve needed a customized one?
  • Vince Becquiot
    April 6, 2011 at 3:08 pm
    [Keith Emroll] “By the way, do you know if there are ways to modify the presets for a sequence? There are numerous pre-sets to choose from, but have you ever been in a situation where you’ve needed a customized one?”
    Sure, just about anything you can think of. Just hit the general tab in your new sequence settings, make your selection, there’s a save preset at the bottom. With the “Desktop” setting (I use this for mixed footage), you have access to about any resolution / frame rate.
    Vince Becquiot
    Kaptis Studios
