Activity › Forums › Adobe After Effects › Losing the alpha channel, when using dynamic link to bring a text layer into after effects
  • Losing the alpha channel, when using dynamic link to bring a text layer into after effects
    Posted by Dave Chavinsky on July 8, 2016 at 3:24 pm
    Hello,
    I have a text layer in a premiere project, which I’d like to animate using the “Stretch in each line” effect, found in AE, but not premiere. When I, replace with AE comp, my text layer turns into a solid black square, with no visable text. It should be transparent.
    The easiest fix is to just delete that text layer within after effects, and make another one, but I want to know what the problem is, so I understand what’s going on..
    Thanks!! screenshots below:
    Premiere (before dynamic link) view:
    Premiere (After DL):
    AE (After DL):
    Walter Soyka replied 10 years, 2 months ago 3 Members · 2 Replies
  • Michael Szalapski
    July 8, 2016 at 3:31 pm
    The “problem” is that After Effects doesn’t recognize Titles created in Premiere.
    Thus, any Titles you create in Premiere will just import into AE as black solids.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Walter Soyka
    July 8, 2016 at 6:21 pm
    Ae started with CoSA and was briefly owned by Aldus, but has been Adobe since 3.0 in 1995. Premiere is all Adobe — always has been — and it even supports many Ae plugins.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
