Activity Forums Apple Final Cut Pro Legacy Losing resolution when nesting sequences into a new timeline
  • Losing resolution when nesting sequences into a new timeline
    Posted by Jessica Keen on June 5, 2010 at 7:09 pm
    I’m working with footage shot on the Canon Rebel T2i. I converted the footage to the Apple ProRes 422 codec using Mpeg streamclip and have been editing with it just fine. (Sequence settings: frame size HD (1920×1080)16:9, compressor: Apple ProRes 422, Quality: 100%, etc.)
    When I take each edited scene and insert them as nested sequences in the timeline, I lose resolution and the image becomes lower grade, slightly pixelated. My sequence settings in the new sequence are exactly the same.
    Thank you for any suggestions/advice you may have!
    Jessica
    Jessica Keen replied 16 years, 3 months ago 2 Members · 2 Replies
  • Chris Tompkins
    June 5, 2010 at 8:12 pm
    do u have a green bar along the top?
    Do u need to do a Full render?
    Chris Tompkins
    Video Atlanta
  • Jessica Keen
    June 8, 2010 at 8:27 pm
    Hi Chris!
    There was no green render bar at the top. There was an orange render bar, so I checked the orange bar (unlimited) in the Render All menu and then rendered the entire sequence. This had no effect whatsoever.
    Any other ideas?
    Jessica
