Activity › Forums › Adobe After Effects › Losing alpha…
Ed Gilbert
May 25, 2011 at 6:05 pmThank you guys! I figured it out… after being schooled a little.. 😉
It was the Render>Transfer Mode setting in Particular. I had set it BACK to Normal. I thought that was the default. By default it is None… And of course when I set it back to None… I have transparency.
And that kids… is why you shouldn’t smoke crack while using After Effects.
Thanks again!
Ed Gilbert
May 25, 2011 at 6:10 pmThanks Darby…
I figured it out a little bit ago… It was indeed the None mode that was the culprit. I posted a thank to close this out,but used the word c r a c k in it and it got flagged for review. So, I’m sure it will show up eventually. But, thanks!!
