Activity › Forums › Adobe After Effects › Lopo isometric infographic animation
  • Lopo isometric infographic animation
    Posted by Eray Ozgen on March 30, 2015 at 10:53 pm
    Hello everyone.. I will be freak out could anyone help me about?
    how I make an animation for isometric infographic vector file in after effects?
    Tried every way that I know but didnt get it what I want.
    Is that about expression?
    is that about plug-in that I didnt know?
    is that about presets?
    I want to make an animation any isometric vector file like that https://vimeo.com/103321763
    I hope, I will find out my answer thank you all
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Matthew Woods replied 11 years, 6 months ago 3 Members · 4 Replies
  • Eray Ozgen
    March 31, 2015 at 6:51 am
  • Joseph W. bourke
    March 31, 2015 at 12:30 pm
    There are a couple of ways to go. From the look of the first link, it appears to have been done in a 3D package, although there are some effects which could be accomplished in After Effects.
    For something such as the building animating and growing, you could draw your isometric drawings in Illustrator, simply using perspective grids, an easy task, and then bring them in to AE, and animate them using something like Ease and Wizz:
    (https://aescripts.com/ease-and-wizz/)
    It also looks as if Newton may have been used in some of the animations which appear to have physics properties (bounce). Animation Composer or Motion Monkey could also be of use in speeding up the keyframing chores:
    (https://misterhorse.tv/products/animation-composer/?mh=vh-handypack
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Eray Ozgen
    March 31, 2015 at 2:39 pm
    First of all thank you so much to replying me
    I have searched what you told me and these info that I have found are useful. But There are no 3d, they are made by Adobe Illustrator cs6 as a isometric. And I have lots of isometric file like that
    https://d3ui957tjb5bqd.cloudfront.net/images/screenshots/products/2/20/20228/set-12-f.jpg?1372724756
    And I want to learn how to animation like that:
    https://vimeo.com/92630207
    there must be easy way to achieve that because different videos but same animation on isometric vectoral file
  • Matthew Woods
    April 2, 2015 at 8:00 pm
    There is no way to make a true isometric view of a 3d scene in After Effects because there is no isometric camera in After Effects. If you need true isometric, you either need to use a different program that does have an isometric camera, or animate in 2d.
    That said, you can approximate isometric, by putting your camera really far away from your scene, and setting the zoom level on the camera really high. This minimizes the perspective in the scene, but you won’t get rid of perspective entirely. It will also make camera moves tricky. If you need camera moves, you are probably best off keeping the camera in place, and moving/rotating the scene.
    Need a quick break from motion graphics?
    Try my game Constellation at:
    https://www.paperdragongames.com
