Activity › Forums › Apple Final Cut Pro › loosing content of connected clips and secondary storylines
Jerome Raim replied 11 years ago 8 Members · 21 Replies
Jeremy Garchow
December 28, 2014 at 5:08 pmWhat did you do right before that? Can you recreate this problem?
Dave Jenkins
December 28, 2014 at 6:17 pmOne thing I do is deselect everything before I make changes. Command Shift A
Even in legacy FCP I would mistakenly have items selected and they would get deleted.Dajen Productions, Santa Barbara, CA
Mac Pro 3.5MHz 6-Core Late 2013
FCP X -
James Ewart
December 29, 2014 at 3:07 amCompletely unhelpful for you but curious about the little yellow markers bottom corner of clips?
Never seen them this end.
Georg Schmitt
December 29, 2014 at 11:37 amOh these are not markers but connections of audio, that is outside the screenshot.
Charlie Austin
December 29, 2014 at 5:08 pmMake sure you are selecting the secondary clip “container” (not the clip in the secondary) when you move them. If only the clip is selected, the container will stay put and the clip will move (or sometimes disappear, which I think is a bug especially with audio only secondaries…)
~ My FCPX Babbling blog ~
~”It is a poor craftsman who blames his tools.”~
~”The function you just attempted is not yet implemented”~ -
James Ewart
December 29, 2014 at 5:36 pmIt’s such a odd problem. At first I thought your lips might just be disabled but clearly not. Or gone offline through not allowing the import render to complete but again not the case. I don’t think I’ve seen this anywhere before.
You’ve trashed the preferences and all that presumably?
Maybe a clean install of the software?
Regards
James
Georg Schmitt
December 29, 2014 at 5:44 pmMy life might wish my lips would be disabled sometimes;-)))
Thanks for reminding me to trash the prefs!
Haven’t done it in a while – as I was thinking it is a user error.
I will do so.For now I make compound clips wherever I have a secondary storyline!
Thanks everybody!
Jeff Bemiss
June 26, 2015 at 2:34 amI’ve had this problem too. In my case, it’s not that media is offline, because I get no flags and the clip I know should be there is still safely in my library.
The two things that make me suspect a bug are 1) as the original poster said, transitions remain inside these secondary storylines, which remain connected where they should be, but the clips are gone, and 2) I’ve had this happen to ALL of my secondary storylines at once, both the above video and the below audio.
I’ve never had it happen more than once per job, and I have noticed that when it does happen, it’s when I am launching FCPX for a new work session. I saw a poster on the Apple discussion forum complaining of the same problem who said it happened when he was duplicating projects and importing XMLs.
Jerome Raim
June 29, 2015 at 6:00 pmA few editors I know have had this happen to them as well. Because it occurs out of the blue without the user being aware of it, it’s pretty much impossible to troubleshoot why/how/when it’s happening.
Maybe it’s because I have the Command+Shift+A reflex, but it’s yet to happen to me. It’s either a bug, or the user is somehow managing to select clips contained within secondary storylines… weird!
Sorry my response isn’t useful, but it’s good to know others are having the same issue.
Jerome Raim
Post-Production
JeromeRaim.com
