Activity Forums Adobe After Effects Expressions loopOut expression not working
  • loopOut expression not working
    Posted by Radheshyam Telange on January 14, 2019 at 6:37 pm
    Following a tutorial they told me to put various loopOut expressions on different rotations of some layers, both PingPong and Cycle, the first ones went well but after working on it for a while the new cycles i created were not working anymore.
    Searching for a solution i found that looking at the Post-expresion graph this was the result: https://prntscr.com/m741dh
    I tried deleting and remaking the keyframes and changing old expressions to match this one, deleting cache, but nothing changes.
    My AE is versione 15.0.0 (build180).
    can anyone help me?
    loopOut(type = "cycle", numKeyframes = 0)
    Radheshyam Telange replied 7 years, 6 months ago 2 Members · 2 Replies
  • Jeff Kay
    January 15, 2019 at 7:20 pm
    How are they not working? Are they returning expression errors? Are they doing nothing? Are they doing something?
    Have you tried removing the superfluous information? It does not need type = or numKeyframes= as it will always read the first value as the first and the second value as the second, additionally 0 for numKeyframes is the default value. In general every line (read line of code, not line of text on screen) should have a semicolon ; at the end of it.
    loopOut("cycle");
    Check to make sure each value that has the expression added to it has keyframes on that value. loopOut functions directly via keyframes and will not work without them.
  • Radheshyam Telange
    January 19, 2019 at 2:58 am
    it won’t do anything, keyframe and everything are there and i also tried deleting the last part ot the expression.
    i partially solved the problem in a layer or 2 by taking a new identical level from my original file and putting it instead of the not working one.
    my guess is that’s just a bug since the new layer is identical to the old one but this one works as it should and the other one keeps giving me that weird graph.
