Activity › Forums › Adobe After Effects Expressions › Loop_out Dropframe
  • Loop_out Dropframe
    Posted by Scarcrowz on August 22, 2007 at 1:01 am
    Hi this is probally a stupid question but i have a comp with some layers in it and everytime I use the Loop expression it drops a frame when it loops at the start. What am I doing wrong?
    This is the expression Im using; loop_out(“cycle”,0)
    It loops fine but seems to miss a frame. Help please!!!
    Greg Neumayer replied 13 years, 1 month ago 4 Members · 4 Replies
  • Dan Ebberts
    August 22, 2007 at 1:19 am
    To get “cycle” to loop smoothly, the last keyframe value needs to be the same as the first. More info here:
    https://library.creativecow.net/articles/ebberts_dan/layer_looping.php
    Dan
  • Filip Vandueren
    August 22, 2007 at 8:57 am
    You’re probably looping time remapping ?
    Quick Fix:
    Go to the last keyframe, go back one frame, add a keyframe, then delete the last keyframe.
    For interlaced: temporarily double the comp’s framerate to do the same, then switch back.
    Long explanatiion why:
    The standard values when timeremapping gets enabled are a bit special:
    Say, if you have a layer of 10 seconds, there’s a keyframe of 0:0:0 at start and 0:10:0 at 10 seconds.
    BUT: there is no movie AT 10 seconds, the last frame of a 10 second clip is at 0:9:24 (in PAL).
    Why does After Effects do this ?
    Because when you’re using interlaced footage, there IS still new information at 0:9:24.5 frame.
    It’s easier to say the movie takes place between 0 and 10 seconds than the movie starts at 0 and ends at 9:24.5
    I hope that was clear.
  • Scarcrowz
    August 22, 2007 at 11:08 pm
    Thanks so much for your time. Yeah I discover that yesterday but now I know why.
    Cheers for your help
  • Greg Neumayer
    August 22, 2013 at 5:11 pm
    Hey Dan,
    Any chance you’ve updated this project to be opened in newer versions?
    Antifreeze Design
    https://www.antifreezedesign.com
