Activity Forums Adobe After Effects Expressions Looping through a shapelayers groups to add things like trim path
  • Filip Vandueren
    March 15, 2023 at 5:13 pm
    A bit tricky, because Groups can be nested. How would you want to handle those cases ?
  • Manuel Moellmann
    March 16, 2023 at 1:17 pm
    you can set a trim path to the very end under all groups and might set it to trim parts individually instead of simultaneously… or maybe use something like foxreveal.
  • Fabian Brugger
    May 8, 2023 at 11:50 am
    Hm basically to loop through all the groups in the first order/hierarchy. Not going into nested groups.
    Is this really not possible? 🙁
